JEWEL FAUCET 12697RIT-21 PRESSURE BALANCED VALVE BODY AND J12 SERIES TRIM OIL RUBBED BRONZE DESIGNER FINISH
The showpiece of any bath presents this Attractive Single Linear Lever Handle pressure balanced Faucet with Designer Finished trim and valve body. This faucet has solid brass construction and smooth operating ceramic control for reliable service while preventing shower shock due to pressure drops in the water supply. Following architectural trends Series J12 is modern simplicity. It's quadratic structure and sturdy contours allow each piece from this line to keep your space looking hip and timeless.
Features- Designer contemporary style adds a unique flair to any home.
- Durable and attractive PVD Finish.
- Pressure Balanced valve with volume control.
- Includes In-Wall Valve Body and Trim.
- Valve body includes integral stops to meet code requirements.
- Stainless Steel pressure balanced spool valve for maximum reliability.
- Pressure balanced valve adjusts for pressure changes to keep the temperature steady.
- Heavy Solid Cast Brass Construction.
- 5.23 Gal/Min. Max @ 60psi.
- Collection Name - J12 Bath Series.
- Designer Finish.
- Decorative Finish - Oil Rubbed Bronze
- Dimension - 11 L x 8 W x 8 D in.
- Item Weight - 11 lbs..
- Made in Italy.
Price: 580.49
